Amp problem?
Jake2727
I have an amp and subs in my car. The amp power light blinks and subs stop working and it goes in and out when music is played. I made sure all the connections were solid, Checked fuses. Not sure where to go from here! Any recommendations?
Right now I have 4 Gauge powering the system.
Here’s some more details on the Amp:
  • each sub handles up to 500 watts RMS
  • 2-ohm total impedance
  • mono sub amplifier (500 watts RMS at 2 ohms)
I did not install this….. Truly have no idea what i’m doing.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
833
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
745
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
203
406
Jake2727
Jake2727
Venice, FL
