Amp(s) for 12 inch warden
Face of Fear
The Beard
564
Iowa
Im aiming for roughly 3k+rms to run this warden. I am at the point where I can either go with one big amp or 2 1500-2k amps. The sub is a dual 2(1.4 ohm dual coil). Does anyone see any issues with running 2 matching 1ohm amps at each coil?
Are you asking for amp suggestions? Or if it's just fine to run 1 amp per coil? If you strap your 2 amps, you will be fine; there's nothing wrong with running a pair of strapped amplifiers to a single subwoofer.
i ran an amp per coil on my 15. it will work and sound nice. just make sure to feed a straight mono signal to each amp and gain match them with a DMM.
Forgot about that; this will work as well if your two amps aren't strapable. If they are, it would be easier to just strap them.
I dont have access to a DMM. The best i can do is just match 2 amps together as close as i can. What are the recomendations for the 2 amps?
Here is what I posted in reply to someone else's thread:
1500 - 2000w and $350 per piece?
Pair of:
Sundown SAZ-1500.1D's, used
Audioque AQ1200D's
Audioque AQ2200D's, used
MBQuart DSC1500.1D's
MBQuart DSC2000.1D's
Audiopipe AP15001D's
Or you could just get a single:
Sundown SAZ-3000D/SAZ-3500D
Audioque AQ3500D.1
Crescendo 3KWP
Crunch GP3000D
Audiopipe AP30001D
I hope you have the electrical to back it up. The single amp route would be my choice - there are a ton of 3000-4000w amps for sale RIGHT at your price point over at CACO. In fact, there's a SAZ-3000D for sale for $525 SHIPPED right now, and an AQ3500D.1 for $600 SHIPPED! Both of which are CHEAPER than your $700 price limit for the amps.
The problem is that your sub is dual 2, so you can count out strapping some of those ~1500w amps. The AQ and Sundown, I believe, will be able to work fine strapped on a 1ohm load, but I don't know about the MBQuart or Audiopipe (since they'd technically be at .5ohm a piece).
And I don't know if those amps on CACO are still available, you'd have to go take a look since this post was originally from a few days ago.
The things in bold would be my choice, with the Crescendo 3KWP being #1. However, they are currently out of stock, and won't have any more until the end of auguest I believe.
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
205
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
408
6
492
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
785
Face of Fear
The Beard
Face of Fear
Iowa
Face of Fear
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
