Amp(s) for 12 inch warden
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
202
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
406
6
491
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
783
Face of Fear
The Beard
Face of Fear
Iowa
Face of Fear
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
