Amp/Speaker compatibility
  • 2
elflamablanca
CarAudio.com Newbie
I have a 2012 IS 250 and I have some questions about the sound system. I have the stock NAV head unit. Currently there is a Kicker CX 600.1 amp . I have 2 10" Kicker Comp S subs
All the other speakers are stock. The 8" stock sub that is in the rear deck is no longer there. It was blown so I took it out and didnt replace it.
I have 4 speakers laying around from my wifes car. They are Kicker CS 6.5 2 way speakers Could these speakers work with the amp and subs that I have in my car?
I know that there is a stock amp in the car and someone said it is connected to my amp via a LOC. Does this amp power all the speakers and the Kicker amp only powers the kicker subs??
Majority of Stock Vehicle speakers are 2 ohm version. Placing 4 ohm speakers on an existing manufactured amp rated for 2 ohms may effect the output on the new 4 ohm speakers installed. You can put in a 4 ohm amplifier and by pass all existing amplifiers with the proper LOC, or simply install another 4 ohm speaker per ch to help with the proper ohm load needed from the existing onboard amplifier.
I looked at the stock amp and it shows all speakers have 4 ohms and the 8" stock subwoofer is 2 ohms.
I ain't bashing the AL sales...I got 3 armada 12's that are sweet and a couple of coworkers got amps and coaxials that sound great...I just don't...
29
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
580
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
489
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
elflamablanca
CarAudio.com Newbie
elflamablanca
Florida
elflamablanca
