Amp To Run On These Speakers?
  • 2
Doxicity
I'm replacing my stock door speakers with something new.
I'm putting in two 15s so I'm looking for something which can be loud enough to hear well.
I was recommended these elsewhere:
http://www.amazon.com/Infinity-Reference-6032cf-6-5-Inch-High-Performance/dp/B002BZFSYA
http://www.amazon.com/Infinity-Reference-9632cf-Performance-Loudspeaker/dp/B002CIU78I/ref=pd_bxgy_e_img_y
Fronts are 6.5s, and backs are 6x9s in my 2000 infiniti g20.
What would be a good 4 channel amp to run on these? I'm trying to keep it to about $250 max for the amp itself.
Also, since those 6x9s can handle nearly double the power, how would I differentiate the power going to the backs, and the power to the fronts?
I'm replacing my stock door speakers with something new.I'm putting in two 15s so I'm looking for something which can be loud enough to hear well.
Amazon.com : Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance 2-Way Speakers (Pair) : Vehicle Speakers : Car Electronics
Amazon.com : Infinity Reference 9632cf 6x9-Inch, 300-Watt High Performance Two-Way Loudspeaker (Pair) : Vehicle Speakers : Car Electronics
Precision Power PPI P900.4 Phantom 4-Channel Amplifier
You use the amplifier gain settings to match the levels.
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
6
93
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
269
Doxicity
Doxicity
New York
Jeffdachef
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
