Amp too powerful?
  • 3
mattwm
Hi all -
I have the Alpine PDX-V9 amp with four Polk Audio DXi650s component speakers rated for 55w at 4 ohms. The amp is rated for 100w at 4 ohms.
I know when tuning the amp you're suppose to set the amp gain to it's lowest setting and then gradually increase until the speakers begin to distort. By reducing the gain a bit, does this determine the maximum power to the speakers for maximum performance and safe operation? Or does it just mean that the speakers can handle it but after so much use they'll end up failing in little time?
Put your crossover at 100hz, turn your volume up to where you listen to your music.. or the loudest you will on the headunit... either by ear set the gain until you hear a slight distortion and back off a bit.. or set with dmm and back it off if you hear distortion. If you have to, you can up the crossover a bit and raise it on your sub to balance it out and help with the mids.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
6
153
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
358
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
348
mattwm
mattwm
Boston, MA
mattwm
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
