Amp too powerful?
It's a MRX-110 Alpine amp, it says that it puts out 1100 watts rms at 2 ohms, but the birth sheet says 1200 rms. I'm going to get two 12'' kicker cvr compvr subs, 400 watt RMS each.
You should be fine as long as your final load is 2 ohm.
Is your box sealed or ported?
You should set your gains with a meter or better yet oscope if you can. So you can always adjust the amp to whatever power output you want. Although your electrical is going to effect this, that amp ONLY puts out 1200 watts at 14V. If you have a 80A alt and bass hits ull drop voltage which drops wattage.
Don't get Kickers, lol. Sundown E series over those any day
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
MyOneSub
MyOneSub
North Carolina
T Reds 19
Decebal
    Jun 10, 2024
