amp turn on wire
  • 2
hellohi
Philly
Hey there, I'm installing an aftermarket head unit, Panasonic 2007, into my 2002 Toyota Echo. The head unit's wire harness has an AMP TURN_ON (12V+) wire (blue/white) but the wire harness that mates with the car does not. What should I do/what will happen if I just insulate the tip of the wire?
(Likely unrelated, the wire harness that mates with the car has a DIMMER wire (orange/white) and the head unit's wire harness does not. My plan for now is to insulate the tip of the dimmer wire and leave it.)
Unless you plan on adding an amp later, I would add some more wire to it, coil it up and stash it somewhere so that next time you have it ready. Otherwise, if not, then cap it off and let her be.
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
824
YES.The Remote wire turns the amplifier On/and OFF. If you use a Toggle switch as stated, use one that Lights up so you know if its still ON or...
5
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to...
6
142
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
326
hellohi
hellohi
Philly
Boomin_tahoe
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
