Amp turns on, won't power subs.
  • 6
I have a Legacy LA770 500WX2 CH amplifier with two Memphis 12" subs. The amp will power on and everything, but I have no sound out of the subs. I've tried so many things, different RCA cables, different ground, and everything. The biggest thing here is that I hooked up the subs to another amplifier and they worked fine, they hit hard and everything. I had everything set up the same. So what is my problem?
I mean the RCA's on the amp itself (The input on the amplifier). Sorry to say it, but Legacy is near the bottom for quality of construction. I have one in my closet next to a Pyramid amplifier (First two my father bought when I was in highschool). I wouldn't be surprised if it was defective.
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
319
455
  • Locked
744
ralph42794
ralph42794
Parkersburg, West Virginia
Pataforce8
