Amp vs amp vs amp
Assuming good electrical and a proper ported box for one CAB ultra 12. Music is rap/top 40. Car is 2006 GTO.
CAB 1600.1
Skar rp1500.1
Audiopipe apcl1500
Any other "better" options under/around $200?
Thanks.
don't get the ap guy here just got one amazon didnt work right, smelled bad. cut off only works at 2 ohm he's selling it probably be glad for u to buy it lol, he stuck with it seller said no refunds or returns.. cab is stronger cause it can run .5 ohm and all but between those 3 i'd get the skar but i'm sure i'm the only one that would say that.. u can look at zapco st maybe..
CAB 1600.1
Skar rp1500.1
Audiopipe apcl1500
Thanks.
I don't think u need the 2k since u have space issues unless u get a huge sub or another car with room for 2nd sub the 1500 will be good for u think..
CAB 1600.1
Skar rp1500.1
Audiopipe apcl1500
Thanks.
30 bucks for an extra 500w is cheap future proofing. Over powering drivers doesnt kill clip does. Small boxes handle more power better so space issues shouldnt be a problem.
211
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
414
6
494
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
789
slm9s
slm9s
WA state
Papermaker85
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
