Mtx 1501
  • 5
irocwagon
cola sc
I don't know if my search button is broke, and I've only found people who don't fix them.. is anyone still around that fix these amps. Plays but ground is loose and rca had a armature repair. It still seems to play fine but I want these two items fixed, I don't think it has any other damage but not 100% sure
MTX 1501D has the led on top
Someone is selling a modded 1501 on caco. Maybe hit them up and ask who did that mod, and maybe they can point you the right direction
you tried ampmedics
Amp Medics Home
Damn there used to be tons of people here that fixed amps. If Ngsm was still here he could definitely point you in the right direction. He used to help me all the time with my mtx 1501s. I'll see if I can't round up someone for you.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
833
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
irocwagon
irocwagon
cola sc
Slo_Ride
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
