Amplifier help
  • 5
ben2003
So I’m putting 2 kicker L7S 12” subs in my car they are dual 2ohm voice coils. I want to wire them to be bridged at the amp with 2 ohm impedance does anyone know what amp that is not going to break the bank that would work best to be ran at 1500watts 2ohm bridged
"I want to wire them to be bridged at the amp with 2 ohm impedance"
This not what you think it may be.
One does not bridge a monoblock subwoofer amplimer, just to set things straight. Bridging is what you do to a multi-channel amp to combine the output of two or more channels to one. You won't be doing that here, with two subs and a monoblock subwoofer amplifier.
With Dual 2 ohm VC woofers, you will need to wire them as follows for a 2 ohm load to the amplifier:
Those Kickers are rated for 750 watts RMS, each or 1500 for the two.
What is the budget, there are plenty of amplifiers out there that work at 2 0hms with decent output. The stinger and Recoil lines offer some decent sub amplifers for the money.
This Stinger puts out 1500 watts at 2 ohmse $200
This Recoil does too $180
3K 3000 watt Taramps $260
Are you set on the Kicker? Lots of 12s out there that I think perform as good or better for less money.
A couple of these 15" NVX for instance $210 each (1200 watts each)
12's $190 each (1200 watts each)
The dual 2 ohm version of these #280 each
These are outstanding subs $269 each
Thank you and I already baught the l7s this is my first time doing 2 sub I used to have a 10 inch kicker comp rt but I ended up under powering it because I just never understood amps and all that but thank you this helped
Thank you and I already baught the l7s this is my first time doing 2 sub I used to have a 10 inch kicker comp rt but I got a underpowered sub for because I just never understood amps and all that but thank you this helped
It's all good, they are still decent enough. That stinger is a great little budget amp too.
If you’re looking for a budget amplifier, I would look at the Taramps hd3000 2 ohm version. You can get one for less than $200 new. Set the gain correctly for 1500 watts rms for your current subs, and not have to change the amplifier if you decide you want stronger subwoofers in the future.
Id spend $10 more and get the 1 Ohm version so that later on if you decide to run a 1 Ohm stage it will serve the need. It will serve the needs for your 2 L7 Kickers @2ohms just fine also.
720
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
ben2003
ben2003
delaware
spokey9
    May 16, 2024
    May 16, 2024
