Amplifier TOXIC TX 1600-N
  • 2
Manu
CarAudio.com Recruit
25
Romania
Hello guys, i'm new on this forum and i have a question for you. I'm using 2 speakers JBL CS1214, 1000w peak, 250w RMS each. These speakers are amplified by a TOXIC TX 1600-N. The question is: can this amplifier run on 2omhs in bridge ? I was searching about this amplifier and i didn't found. Actually i'm using each speaker in bridge on ch 1 + 2, ch 3 + 4. I want to give them more power wiring them in parallel. I hope you will help me with some informations about this amp, thank you!
You already have them in the best configuration for the equipment that you are running. If you want more power, you are going to need a better amplifier
I have one more question about this amp. So this amp can give 200w rms x 2 in bridge at 4 ohms ? Or how much power can this handle?
MOS-FET PWM Power Switching Supply with Softstart
adjustable High-Pass 40 Hz - 240 Hz
adjustable Low-Pass 40 Hz - 240 Hz
Bass-Boost 0,6,12dB switchable
Line Out
Specification
Max Output Power: 4 x 400W, RMS 4 x 200w
Max Bridged Output Power: 2 x 800W , RMS 2 x 400
Highpass: 40Hz - 250Hz
Lowpass: 40Hz - 250Hz
Frequency Range: 10Hz - 40KHz
S/N Ratio: 100dB
Dimensions: 420x57x308mm
Damping Factor: 180
These are some informations about this amp but idk if this power is for 2 or 4 ohms.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
7
712
726
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
9
780
Manu
Manu
Romania
Manu
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
