Dodge Neon 5-channel amp - SQ and efficient
  • 2
Gary S
Hi guys,
I've been out of car audio for awhile. I have a 2002 Dodge neon and I'm going to put high end, new (old school) PPI DCX 525S comps in the doors, subs in the trunk, and I have a Sony DVD player with Dolby surround. I'll add surround sound rear deck speakers at a later date.
I want to buy an amp.... This is a Dodge neon so it's a little compact car.... the battery is really small, it looks like the battery wires are only 8 gauge, lol
I just want a sound quality system, not interested in turning heads outside the car.... I'm thinking a 5-channel full class D amp for efficiency, around 700 to 900 watts total rated RMS.... Is this car/battery going to be enough for one moderate/small amp like that? I have 4-guage wire I can run to the battery.
I'm thinking full class D?
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=393139334694
I myself was thinking about trying one of these out,. But I ended up getting my PPI Phantom 5 ch. out of the box. Specs look good, and look like plenty of setting adjustments for tuning, and a space saver also. it prob wouldnt hurt to try and get the Big 3 done and look at a pretty decent AGM under the hood for future power needs. I had a Honda CRV with a 90 amp alt. and ended up running 2 Good sized AGM batts( 1 under the hood and one in the rear) and did the Big 3 and seemed to have had plenty of supply for the demand. Ran 2 ga
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
983
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
3K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Gary S
Gary S
Ex JL Audio Rep
audiobaun
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
