Amps with digital input?
I don't even think zapco has digital inputs on amps...
That's correct, they have symbilink balanced (analog) inputs. To have a digital input at the amp would require a D/A built into the amp. Personally, I like the idea. Building on the Zapco idea, all you would need is a headunit that provides a digital output. Each amp would have it's own crossover, eq and D/A convertor. Expensive on the amp side but a very simply system. One headunit and one 5 or 6 channel amp would be all the electronics most systems would need.
No companies make amps with digital inputs.
There is no such thing as a digital amp. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
In the car stereo world (which may be the only thing you have any knowledge of) both of these statement are true - best as I know of ....
In the rest of the world, they are both both false
What about the older MA audio HK4000D and visonik's V4000XD ? They claim to be digital class X amps.. The quantization of the output signal at the power stage can be controlled by either an analog signal or a digital signal. Only in the latter case would an amplifier be using fully digital amplification.
I think the OP is only curious about amps that have a D/A converter in them. That is, an amplifier that takes a data stream of 1/0s that represent a waveform straight from a head unit or other signal carrier and converts them to an analog waveform to be used by the input stage of the amplifier.
453
576
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
KyngHype
Bass head to SQ convert
KyngHype
Las Vegas
ciaonzo
Decebal
    Jun 10, 2024
