amps
  • Thread starter <jon>
  • Start date
  • Replies 1
  • Views 2K
    Participant list
Class D amps use less battery/alternator power to make power. They're 2 times or more efficient than most amps and run cooler.
They work best on subs as they distort and make more noise than class A/B amps.
They're great for subs and easy on your car. I wouldn't buy anything else for subs unless I was going for the best sound quality possible.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
158
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Guest
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
