Right amp for the Right subs
  • 4
Heresy
Going Against the Grain
1,216
Arizona
I just got 2 MTX Thunder4000 4 ohm 12' subs. I'm looking at hooking them up to a Audiobahn A8001D 800w 1ch Class D Amp. Is this a good idea or is there something else that would substitute better? I can get Audiobahn amps cheap but I don't know the track record or how it will pair with the subs I have.
I would suggest going with the MTX Thunder 4250 class d amplifier, it will give your subs 350watts rms if you parrallel the 2 subs. The thunder 4000 subs will not handle the 800watts rms(400 each) that the Audiobahn 8001D will give them. The mtx 4250D is designed to run the thunder 4000 subs, so it should give you the best possible performance.
well, the audiobahn amp would work. however, if you run it,make sure that your gain is down. if not, and you try to crank it, kiss your subs goodbye. i think they mtx that was mentioned before would be a better bet too. MTX makes their amps to run their subs and makes their subs to run off their amps. ive heard straight mtx sytems and thet bumped lik crazy. but, either would work
$600 for is aweful pricey for what you get with that amp.
MTX 4000 12's are rated @ 200W RMS. I'd go with a less costly lower power amp.
Harrison Labs makes a 2ohm 400W mono class d amp for $300 and 800W for $350.
Do some more shopping and save a bundle o cash.
the kicker zr360 or the zr600 amp would be a good choice
they can be bridge to 2 ohm mono they also have
plug in module (swx) so you can send a low pass
signal to your subs
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
964
That heatsink's shape, color, and plexi bottom is just like the US Amps. I like it.
5
Complete novice at this so that is why I am here. Looking for guidance on what type of speakers I should be looking at getting to replace the...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Heresy
Heresy
Arizona
billetz23
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
