an rca jack fell off subamp, and touch the amp casing.... i smell smoke help
  • 3
Arawak420
We Are Creatures Of Love
poineer deh80pr, Rockford Fosgate T10001bd on 2x 1200wt diamond D612D4 ran in 2ohm in ported spec box I made.
I bought the amp here in 2006 (Subs new at sonix 2006). Blessed that dood cause it's been serving me well till now due to my failure.
I Turn on my stereo and static chaos and the smell of smoke insued. Turned it off went to the sub and a **** rca jack fell off touchin the casing. the external 150wt fuse didn't blow. he blue light doesn't power now no sound. I have another door speaker amp and it's powering and working fine. Gonna test sub amp rca line on door speaker amp.
What happened to the amp?
Is this amp repairable?
Worth repairing?
Average Cost to repair?
Can you Recommended me some 700-1000wt D class amp in $100 range used or new
System has been great since 2006 in the same vehicle. . This amp bangs on the diamonds.
blessings to you guys around her help make my decision.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
665
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
668
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
584
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
754
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
889
Arawak420
Arawak420
Lost Angels, Ca
C1500martin
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
