ANL fuse block needed
So, as I recall, you are running the 2/0 to the second battery. Then from the battery/ run 1/0 or 2/0 if you have it to spare, that section is so short it won't really matter) to that 8 post unit, linking the initial input on the outer 3 on either side, 3 for the ground and 3 for the positive with 3 hole buss bar links or plates you could make out of copper or aluminum on the input side then through the fuses to the 3 +/- on the HCCA and leaving the two in the middle for the 4 gauge runs to the two Massive amplifiers.This seems to me to the least complicated and the least expensive way to to run it. Remind m
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders.
Depending on how you're wiring this up, would one of them be for the sub amp?
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Sounds like a bad ground or wiring problem on the 12v+ side.
13
CarAudio.com Regular
HardofWhoring
    May 16, 2024
    May 16, 2024
