another big 3 issue
  • 3
tdford5
ohio
going to do the big 3 on my hhr but a couple issues come into play , factory battery is located in the trunk my wire the is bolted on the alt runs down to the starter then splits off up to the under the hood fuse box where there is a jump start point then splits again and i imagine from there goese to the trunk where the battery is located ive search and found no big 3 which battery location is in the trunk and should i run double inline fuses if so where any help is appreciate thanks
So what you would need to do with whatever sized wire you are using:
Ground bat to frame in rear
ground engine block to frame in front
run a single run from alt positive straight from alt to battery
---------- Post added at 07:13 PM ---------- Previous post was at 07:13 PM ----------
What I would do:
run pos to rear battery
run alt bracket to rear bat negative
ground alt bracket to frame
ground battery to frame.
So what I would do is do 2 runs of 0 gauge to the rear, 1 from alt + to batt +. The other alt bracket to batt -.
Ground battery to frame in rear.
Ground alt to frame in front.
ok thanks buck i know the battery is ground to the chassis in the trunks already so just need to ground the alt to the chassis in the front ,ok so im running stock 110 amp alt what size fusing would u recommend ? what the advantage of running ground from alt bracket to the batt in the rear?
man I love the easy wiring I had becuz of the short run from bat to my amp I'm goin to hate the
big 3 thou arghhh...
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
209
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
801
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
tdford5
tdford5
ohio
tdford5
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
