Another power wire question
  • 3
AnthonyO
Budget Banger Connoisseur
So I have 4 gauge OFC run right now. Because I was running a Kicker Key 500.1 and 180.4. Maximum of 80 amps.
Now I am switching to the Stinger MT1000.1 and Audio Control ACM 4.300. So a total of 130 amps.
I know the wire charts show 1200 watts on 4 gauge 13-16ft runs.
Should I change out the wire to 2 gauge welding wire? Or trust the chart?
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see if it has gotten pretty warm or not. If it gets warm, Id replace it, but 4 ga OFC should be able to handle around 150amps
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
AnthonyO
AnthonyO
Minot, North Dakota, United States
audiobaun
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
