Another Custom Install
If you want my honest opinion, those corner pieces on the back wall above the sub enclosures look like crap.
Why didn't you make that one solid piece all the way across instead of trying to piece things together?
A true audio fan doesn't have time to look pretty //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
We be changing our setups all the time to better and greater things....
BS, it still needs to look good!
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
---------- Post added at 03:47 PM ---------- Previous post was at 03:47 PM ----------
I'm not very good at looking good. Looking good takes too much work, especially when you take systems in and out as much as I do.
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
630
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Desmond Audio
Desmond Audio
Rockford IL
I Like Waffle
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
