Another expense
  • 3
LosIsATool
This summer heat is messing with my slash amps. They naturally run warm but the rack is heating them up to the point where they are cutting power when I listen to stuff like Killswitch engaged. $60 for a pair of cross flow fans when I didn't want to spend another dime on my audioz! If I don't do it now they are going to die when I move to Florida soon. Can it just end?
I am in Florida it is hot as hell
but my amps do not shut down due to it
sometimes you need to step over the penny to pick up the dollar
Dude the penny has been crushed. The rack has them pretty covered up and they are slash amps. They don't go thermal they cut power. They are cooled down now and fine.
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
413
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
852
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
LosIsATool
LosIsATool
Pensacola, Florida
LosIsATool
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
