another vs. thread between Dcon vs. sundown e series vs. obsidian
Can't speak as to which sub to choose but if you have three cubes to work with, why not go with a single 12" ported? I tend to prefer ported vs. sealed, mainly because I'm used to the sound and they're more efficient off less power.
Really looking to go sealed this time. I know a properly tuned box can sound as good as sealed and get as low but imo, sealed lows just does it for me man!
i would say the dcon but you would have to be very carefull with setting gains, The obsidian is your best choice, 3 cubes should be fine sealed
Cool, exactly what im wanting to hear
For sure I prefer the Dcon. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Just set gains properly and build a great box, win. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
may be what ill have to do,seems like the Obsidian is not in stock
amazing deal here and will sound amazing and take 500rms no problem 2.5 inch coil
The G3 is on Sonic as well for 150 shipped. Excellent subs...
edit* Nevermind. Sonic says they're discontinued. Going to be a lot of this with BA. If I had some monies I'd stock up on some stuff.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
597
They managed to turn Covid into a wedge issue.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Ridinhi
Ridinhi
Winston-Salem, NC
mclerico83
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
