ANOTHER what sub / box question
  • 1
Beau M
Hi all been a while.
I have a 2014 Nissan Frontier Crew Cab.  Currently I have a cheapo pre-fab 1 cuft sealed box with two Fosgate Punch 10" shallow mount woofers.  Running around 800 watts RMS to the pair, down firing. This thing:
The bass is very peaky around 100hz with almost no low end extension, it sounds just like the box is too small for subs.  I've been messing with amp / eq setting for a year now and just can't get the sound I want.  I want to get low.
I came across a better quality, ported sub box here:
https://www.soundoffaudio.com/ported-dual-sub-box-2005-2016-frontier-crew/
It is advertised as also being 1 cuft, ported to 39hz, for two 8" subs.
Here is my dilemma.  That still seems too small, especially ported.  I can't find any 8" subs that would be happy in .5 cuft ported.  So, assuming I am using that box, which would be better:
Two 8" subs like the Skar VD-8
https://www.skaraudio.com/products/vd-8-inch-car-subwoofer
One 8" sub that has the whole box to itself?
What about two 6.5" subs like the Skar EVL-65?
https://www.skaraudio.com/products/evl-65-inch-car-subwoofer?variant=18454532865
I just don't know if my issue is due to the subs down firing or the box size or what.
What would you do?
-Beau
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
584
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Beau M
Beau M
Burien, WA
Beau M
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
