Another which amp thread
aemeth
15
NW WI
Just getting into car audio so be kind.
I have 2 dvc rockford fosgate hx2 10's (500rms) Sealed 1.5cf box.
I know these amps are overkill but eventually I will be upgrading my subs. Ive narrowed it down to 3
http://www.sonicelec...BRZ2400.1D.html
on my local clist theres a used aq2200 for $300
Sundown Audio SAZ1500D V1s for $275
Id consider the crescendo 2000 but its on backorder..
I'll also be doing the big 3 upgrade. I can add a second alternator and battery if needed, but i dont 'think' ill need to get that serious yet.
Right now im more concerned with sound quality (I listen to alot of rock) than I am with brute force. But i think eventually ill want more sound pressure so I want an amp I can 'grow into'
Just getting into car audio so be kind. I have 2 dvc rockford fosgate hx2 10's (500rms) Sealed 1.5cf box.
The sundown isn't a bad deal. it would have decent sq and they're reliable. Gets my vote, especially if you can get a few bucks knocked off.
- Get the Crescendo amp... i ordered two different amps,
one of them was said to be on backorder, but it was delivered before it was due to be in stock .
These are Bad A$$ Amps, worth the wait !
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
632
Haven't 100% landed on which one, but I am down to those two
12
They managed to turn Covid into a wedge issue.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
aemeth
aemeth
NW WI
Bettr n' Revrse
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
