anti-shock problems
Hey guys... I'm not really experienced with the car audio scene yet... but I'm getting into it...
Anyway at the moment I have a (I know its old and ****) SONY CDX-5090 CD head... replacing it is not an option for now... because I have little money and want to buy an amp/sub first... So I was wondering if you guys cud help me with it?
Well the problem is it doesn't like playing CDR's very much at all... it'l play them but it skips a LOT... and regular (pressed) CD's aren't much better... Anyway I was wondering if there is anything I can do to improve the antishock, or how much its likely to cost to repair...
I really don't wanna have to take it out, replace it with a tape head and a carkit...c u!
ED
yo, i would suggest using sony cd changer. the newer models should have no problem with cd-r's or skipping. it should not be too expensive either.
you might want to check and see if you have a ground wire in cuz we forgot to put one into my sises car and her cd player skipped alot until we put one in
You said it's an older Sony CD player model. many older CD players won't play CDR's because of reasons that I don't know as I have never dealt with CDR, only read about them. When a CD player can't play CDR's, often it will react by skipping.If it's skipping otherwise I'd check connections and proper tight mounting. It also may need to be cleaned or replaced.
in past experience with the models made around that time by sony, I dealt with a lot of customers that had skipping probs after about a 2-3 year time of ownership. They just aren't that good. My suggestion would be to put something on layaway If you don't have much flow. repair on that unit will be almost as much as another cd player.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
764
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
816
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
Eddiewould
Eddiewould
Wellington, New Zealand
gregj9
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
