By Passing the factory amp in a 2000 Ford Windstar
  • 2
if you go to a local car stereo retailer, they sell bypass harnesses for factory amplifiers. Or, you could find out where the factory amp is and on the output side you could run wires from your head unit to there and pick up the speaker wires at that point to avoid running wires to all the speakers
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
973
Homer29687
Homer29687
Greenville,South Carolina
gregj9
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
