any one w/ half a brain plz help- cut through?
  • 2
Puff the dragon
15
ohio
I have a 99' Dodge Dokota R/T regular cab with 6 MTX 8000 series 12's and 3 8100D 1500w amps in the bed. I have a 8" x 40" cut through in the cab but since they are 12" subs, they are pounding on the sheet metal of the cab and about half the sound is getting through to the dash. I can't really cut any higher because of wire harnesses from the factory. Help me out if you got any ideas, I am only hitting 148! With 6 12's it should be a bit higher.
Thanks
jesseborgelt@hotmail.com[/email]
I am not sure I am reading this right but I have no audio knowledge really compared to you guys but I would build supports in where the cut is say every 10" but a verticle post!
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
Damn.. thank you man... I wasn't expecting you to do all the work for me but I'll definitely take it lol. Thank you so much and also thank you...
5
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
635
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
Puff the dragon
Puff the dragon
ohio
jrmax
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
