AQ1200 protect mode.....
  • 2
crazy4life
Finally got around to testing out my older model AQ1200. It worked wonders for about 15mins then it went into protect... Turning the deck on and off would bring it out of protect but slowly it would last less and less.
Fast forward a year later its still doing the same thing except now it goes into protect as soon as possible... You also have to let it sit now before it will work again. I have not yet tested it in another vehicle but im certain something is wrong with the amp as my friends amp works wonders.
Iv opened it up and nothing looks burnt, blow, expanded caps. Nothing. I did break the stuck master/slave switch thou.
Options?
I want to hear my IA DR in my tiny bmw e36 :p
Why didnt you send it back to AQ when the first problems occurred? Ide get it fixed, or have it looked at. Give AQ a call and see what they say, i love my AQ1200 its deff worth getting looked at
I had money problems at the time... Iv already emailed them just waiting on a response. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
11
You don't understand understand brazilian amps and how finicky they can be about voltage...everything you just said nonsense
13
crazy4life
crazy4life
vero beach, fl
crazy4life
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
