Amps on protect
  • 3
sameboysamesame
CarAudio.com Newbie
My door speaker was cutting in and out for a few days. I found the issue. It was a loose rca wire. But now that I’ve plugged it back in, my interior amp and also subwoofer amp are both on protect. I have absolutely no audio whatsoever. I have no idea what caused this and don’t know how to fix it without buying new amps. I don’t want to run into the same issue if I spend money for new equipment. Can anyone help me with this fix? Thank you in advance
Where is the RCA in the chain? Maybe the RCA is actually no good or not grounding correctly? Sound's like you have a short or grounding issue somewhere.
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the amplifiers in the OFF position, and see they they go out of protect when you turn them back on.
Try that First and let us know what happens.
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
338
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
878
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
996
sameboysamesame
CarAudio.com Newbie
sameboysamesame
Houston,Tx
audiobaun
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
