are bass knobs all they're cracked up to be?
With a properly set gain I don't see why it would be a negative thing. Mine does make a sorta low pop/scratch noise when turn from off to slightly on but nothing that would ever blow my sub.
depends on the kind of bass knob and if you set your gains properly. Some bass knobs are centered around a specific frequency ex 45hz. So when you turn up the knob, you are not turning up all bass, just boosting that one area. Others boost the gain of the amp, so all frequencies that are going to the sub. In both cases you want them to be at full when you set the gains and then turn them down when you want less bass. If you have them low when you set your gain, then try to get more bass out of your system from the knob, you will just be clipping your amp.
I run two knobs in my dash one controls the attenuation of my sub amp via patching through the rca's and the second one is a boost knob on my high's but it works by the fact RF shows you the curve of the boost on hpf with the slope and roll off from 15khz so I used that so I have an equal opposite slope set on my HU's eq.
seems like a good idea, but i hear a lot of negatives about them too
In general, it depends on the user and the boost remote, some have a clipping indicator light. With the system properly set up to begin with, it should not ever be needed.
If you are referring to the boost knob on a low wattage class A/B amp, such as the one in your sig, I would highly recommend against it. The subs you have may not be the best there is, but that amp will kill them if driven beyond it's means.
I kinda like the use of my gain controls over the years its much easier to cut my subs down via a turn of a knob when playing rock rather then going threw my massive HU menu to find where the sub control is.... Just be sure to have knob connected to amp and turned all the way up before you set your gains on amp........ If not you will find out why lol
I'm not familiar with Vertigo amplifiers. If they have a master-slave setting, you only need one gain. otherwise, @dragon.breath nailed it.
967
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
343
Defiantly. LOL 😂 It has never happened to me👀:poop:
6
530
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
8
589
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
ChevyRidinLow
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
