As loud as possible subwoofer system recommendations (Audi A4 B5 Sedan)
I have a crazy trunk build and might be able to give you some advice. Check out the trunk build only Facebook group.
Rough cost breakdown (You could make some more sacrifices but this is best price to performance):
Used American Bass HD 12 or similar subs - $700-800
Used Taramps 8k (go full bridge at this budget or look into CAB-45 at half ohm) - $450
HO Alt + 64AH Headway bank - ~$800
Box - ~$350
Wire and misc - $350
Total: $2750
You're going to have to choose between hair tricks (windy/lower tune) and being loud (high tune) to an extent.
I'd personally go with one of two options (both enclosures on the smaller side tuned ~32hz):
With your budget you will want to tune a bit higher to get loud, probably 32-36hz.
Option 1:
Side aero port
31936
Option 2:
Forward aeroport (I would go with this tuned to 32hz at about ~4ft3 depending on woofers)
31937
You will want the most power your budget can allow. If you can get good priced or used equipment it will allow you to spend more on batteries and alternator which will help you a lot. Check out DIY headway lithium banks.
This is my build which I spent ~$7k and I get decent hairtricks at a select few frequencies (specs in signature). Probably clamping ~5-6kw. I have a big enclosure with a forward slot port which I regret somewhat. It's not as loud as a side or forward aero and I do have some loading issues with certain windows down. 5ft3 is a big large to put a lot of power to and the woofers do start to lose control near rated power. I did seal since this pic.
31939
31940
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
900
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
4
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
4K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Bixmox
CarAudio.com Newbie
Bixmox
Norway
Jonnyswboy
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
