ASWC-1 Steering Wheel Controller and my 2017 Elantra
  • 1
PaleHaunt
CarAudio.com Newbie
Hey Gang, came here for some help...
I have a Hyundai Elantra SE 2017, and it had the very standard radio system. Just a regular head unit, not even a touch screen. I replaced the entire system. This is what I have installed...
Sony XAV-AX5000
Alpine KTP-445U 4-channel Power Pack Amplifier
(Front) Infinity PR6500CS Primus
(Rear) Infinity REF6522IX
SiriusXM SXV300V1 Tuner
Axxess ASWC-1 interface
The Axxess ASWC-1 interface is labeled as "Untested" on their website, so I can't find an installation guide for my car, and I can't even get the unit to power on, so I clearly hooked it up wrong. The funny thing is, the wiring harness I bought is from the same company, Metra, and they say at the bottom of their harness instructions, made for my vehicle:
Connect the following (2) wires to the AXXESS ASWC-1 Steering Wheel Controller Interface (sold separately):
GREEN/ORANGE - SWC1
BLACK near GREEN/ORANGE - SWC GROUND
What the hell is "BLACK near GREEN/ORANGE - SWC GROUND" near. NEAR? I don't know what this means. At all. I've looked at a hundred different installs, trying to figure this out, and I'm lost. Some say it won't work, others swear there's does. ALL I need is the volume and track skip to work. Basic. Is there ANYONE who has done this, or can explain to me, like I'm a idiot, how to wire this in? I install the entire rest of the set up myself, all works perfectly. Not this. Frustrating to say the least.
Well, I got it powered up, and it runs through it's program cycle but then flashes the green red green red showing it's not programmed. I can't get it to recognize the car, even holding up the volume. Maybe it's just not compatible.
thanks for your time in replying and the effort you have obviously gone to, my radio only has just one single wire for the steering wheel control...
4
Not enough information. Some remote units are radio specific while others are stand alone.
Did the instructions on the back of the main module not work? They are vague but give you a general procedure.
Update: I emailed Atoto support. They are asking me which wire in this Simple Soft CAN BUS controls the steering buttons? If I knew that, I...
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
5
PaleHaunt
CarAudio.com Newbie
PaleHaunt
PaleHaunt
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
