Atomic, Kicker, Polk, Hifonics, Amps, Subs, Crossovers, Enclosures, Lot of stuff!
72Impala
1. Product: Listing everything I am not currently using, looking to trade or sell. All prices are PLUS ACTUAL shipping, I do not want to make money off shipping, if you buy multiple items I can possibly save some money on shipping by shipping them together, but prices are not shipped. PREFER to TRADE, but prices are listed.
1 - 2 10" D1 Atomic ELE/APX hybrids, never had power to them, recently reconed ELE motors with APX soft parts, polished magnet, polished basket. 2000+ WRMS easy.
$260 Per woofer, prefer to sell together for $500.
2 -(sold) DD6.5SW D4 mounted in LE-MO6 box (made specifically for this driver). This thing pounds for a 6.5" sub. 250WRMS (very underrated). Used in my truck for a little bit but now wanting to move to 8's, under 1 hour of play, probably more like 30 minutes. Will separate from enclosure.
$100 for the Sub, $60 for the enclosure. $150 together.
3 - (SOLD)Old School 12" Kicker CVR in sealed box with grill. 500WRMS I believe, Single 4 ohm (I Believe, have to check, been awhile), Just tested it today and it still works perfectly, its a wedge sealed box. Will separate from box.
$60 for the Sub, $100 for sub and box.
4 -(1 LEFT) 2 15" Kicker L7's. 04SL7D4 models. The one on the left works, just feels a little looser than new. The one on the right is blown. I can get rid of them separate, take them apart, send them as is, whatever. These can be reconed or changed into round woofers.
$100 for the good one, $50 for the blown one. $ 140 together.
5 - Hifonics Brutus 25th anniversary 2608D. Used, has some wear on the outside, works perfectly. 1700WRMS @ 2ohm, 2600WRMS @ 1ohm (as per manual which is included). I have heard many different things about these, some people hate on Hifonics, I don't, I do not know if it does exactly 2600WRMS or not, but there are people all over the internet that have tested them and came up with numbers around that. Its a great amp.
$215 for the amp
6 -(SOLD) Hifonics Titan TXI 6006. Used, some wear on outside, works fine. 150 X 2 @ 4ohm, 300 X 2 @ 2ohm, 600 X 1 @ 4ohm bridged. It is linkable. Again its hifonics, so probably in my opinion does right around rated. I barely used this thing, did for a little while on the 12" Kicker CVR above for a short time bridged and it was a good match.
Asking $80
7 -(SOLD) Planet Audio P9740. 7in in-dash double din. Works fine, plays dvd's and cd's, has the micro usb thing on the front. Never used it myself, got it in a trade.
Asking $50.
8 - Raptor power distribution Block. 1/0 in, 2 x 4ga. out. Comes with one 200A fuse and one 150A fuse in it. Lights up blue when connected.
Asking $5
9 - (SOLD)Polk Audio DXI crossovers x 2. Came with DXI 6500's. Switched to something else, they work, missing a couple screws.
Asking $5 for both
10 - Polk Audio Grill's. 1 pair for 6.5 speakers, 1 pair for 5.25 speakers. Few dings here and there.
Asking $2 per pair
11 -(SOLD) 15" sub Box. 3.3 Cubes tuned to 35HZ. One corner has the carpet frayed. It is a SPL geared box, Double baffled.
Asking $50
I am looking for 8" woofers, and a 3K + amp. That is really it. Multiple 8" woofers, 2 amps that equal 3-4K, or one amp that is 3-4K. :
2 - DD6.5SW D4 mounted in LE-MO6 box (made specifically for this driver). This thing pounds for a 6.5" sub. 250WRMS (very underrated). Used in my truck for a little bit but now wanting to move to 8's, under 1 hour of play, probably more like 30 minutes. Will separate from enclosure.
3 - Old School 12" Kicker CVR in sealed box with grill. 500WRMS I believe, Single 4 ohm (I Believe, have to check, been awhile), Just tested it today and it still works perfectly, its a wedge sealed box. Will separate from box.
4 - 2 15" Kicker L7's. 04SL7D4 models. The one on the left works, just feels a little looser than new. The one on the right is blown. I can get rid of them separate, take them apart, send them as is, whatever. These can be reconed or changed into round woofers.
$215 for the amp
6 - Hifonics Titan TXI 6006. Used, some wear on outside, works fine. 150 X 2 @ 4ohm, 300 X 2 @ 2ohm, 600 X 1 @ 4ohm bridged. It is linkable. Again its hifonics, so probably in my opinion does right around rated. I barely used this thing, did for a little while on the 12" Kicker CVR above for a short time bridged and it was a good match.
Asking $80
7 - Planet Audio P9740. 7in in-dash double din. Works fine, plays dvd's and cd's, has the micro usb thing on the front. Never used it myself, got it in a trade.
Asking $50.
Asking $5
9 - Polk Audio DXI crossovers x 2. Came with DXI 6500's. Switched to something else, they work, missing a couple screws.
Asking $5 for both
Asking $2 per pair
11 - 15" sub Box. 3.3 Cubes tuned to 35HZ. One corner has the carpet frayed. It is a SPL geared box, Double baffled.
Asking $50
Still interested in my 9918?
Fantastic find. Thank you for sharing this.
14
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
818
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
72Impala
72Impala
Clarksville, TN
72Impala
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
