Atomic, Kicker, Polk, Hifonics, Amps, Subs, Crossovers, Enclosures, Lot of stuff!
72Impala
1. Product: Listing everything I am not currently using, looking to trade or sell. All prices are PLUS ACTUAL shipping, I do not want to make money off shipping, if you buy multiple items I can possibly save some money on shipping by shipping them together, but prices are not shipped. PREFER to TRADE, but prices are listed.
1 - 2 10" D1 Atomic ELE/APX hybrids, never had power to them, recently reconed ELE motors with APX soft parts, polished magnet, polished basket. 2000+ WRMS easy.
$260 Per woofer, prefer to sell together for $500.
2 -(sold) DD6.5SW D4 mounted in LE-MO6 box (made specifically for this driver). This thing pounds for a 6.5" sub. 250WRMS (very underrated). Used in my truck for a little bit but now wanting to move to 8's, under 1 hour of play, probably more like 30 minutes. Will separate from enclosure.
$100 for the Sub, $60 for the enclosure. $150 together.
3 - (SOLD)Old School 12" Kicker CVR in sealed box with grill. 500WRMS I believe, Single 4 ohm (I Believe, have to check, been awhile), Just tested it today and it still works perfectly, its a wedge sealed box. Will separate from box.
$60 for the Sub, $100 for sub and box.
4 -(1 LEFT) 2 15" Kicker L7's. 04SL7D4 models. The one on the left works, just feels a little looser than new. The one on the right is blown. I can get rid of them separate, take them apart, send them as is, whatever. These can be reconed or changed into round woofers.
$100 for the good one, $50 for the blown one. $ 140 together.
5 - Hifonics Brutus 25th anniversary 2608D. Used, has some wear on the outside, works perfectly. 1700WRMS @ 2ohm, 2600WRMS @ 1ohm (as per manual which is included). I have heard many different things about these, some people hate on Hifonics, I don't, I do not know if it does exactly 2600WRMS or not, but there are people all over the internet that have tested them and came up with numbers around that. Its a great amp.
$215 for the amp
6 -(SOLD) Hifonics Titan TXI 6006. Used, some wear on outside, works fine. 150 X 2 @ 4ohm, 300 X 2 @ 2ohm, 600 X 1 @ 4ohm bridged. It is linkable. Again its hifonics, so probably in my opinion does right around rated. I barely used this thing, did for a little while on the 12" Kicker CVR above for a short time bridged and it was a good match.
Asking $80
7 -(SOLD) Planet Audio P9740. 7in in-dash double din. Works fine, plays dvd's and cd's, has the micro usb thing on the front. Never used it myself, got it in a trade.
Asking $50.
8 - Raptor power distribution Block. 1/0 in, 2 x 4ga. out. Comes with one 200A fuse and one 150A fuse in it. Lights up blue when connected.
Asking $5
9 - (SOLD)Polk Audio DXI crossovers x 2. Came with DXI 6500's. Switched to something else, they work, missing a couple screws.
Asking $5 for both
10 - Polk Audio Grill's. 1 pair for 6.5 speakers, 1 pair for 5.25 speakers. Few dings here and there.
Asking $2 per pair
11 -(SOLD) 15" sub Box. 3.3 Cubes tuned to 35HZ. One corner has the carpet frayed. It is a SPL geared box, Double baffled.
Asking $50
I am looking for 8" woofers, and a 3K + amp. That is really it. Multiple 8" woofers, 2 amps that equal 3-4K, or one amp that is 3-4K. :
2 - DD6.5SW D4 mounted in LE-MO6 box (made specifically for this driver). This thing pounds for a 6.5" sub. 250WRMS (very underrated). Used in my truck for a little bit but now wanting to move to 8's, under 1 hour of play, probably more like 30 minutes. Will separate from enclosure.
3 - Old School 12" Kicker CVR in sealed box with grill. 500WRMS I believe, Single 4 ohm (I Believe, have to check, been awhile), Just tested it today and it still works perfectly, its a wedge sealed box. Will separate from box.
4 - 2 15" Kicker L7's. 04SL7D4 models. The one on the left works, just feels a little looser than new. The one on the right is blown. I can get rid of them separate, take them apart, send them as is, whatever. These can be reconed or changed into round woofers.
$215 for the amp
6 - Hifonics Titan TXI 6006. Used, some wear on outside, works fine. 150 X 2 @ 4ohm, 300 X 2 @ 2ohm, 600 X 1 @ 4ohm bridged. It is linkable. Again its hifonics, so probably in my opinion does right around rated. I barely used this thing, did for a little while on the 12" Kicker CVR above for a short time bridged and it was a good match.
Asking $80
7 - Planet Audio P9740. 7in in-dash double din. Works fine, plays dvd's and cd's, has the micro usb thing on the front. Never used it myself, got it in a trade.
Asking $50.
Asking $5
9 - Polk Audio DXI crossovers x 2. Came with DXI 6500's. Switched to something else, they work, missing a couple screws.
Asking $5 for both
Asking $2 per pair
11 - 15" sub Box. 3.3 Cubes tuned to 35HZ. One corner has the carpet frayed. It is a SPL geared box, Double baffled.
Asking $50
Still interested in my 9918?
Fantastic find. Thank you for sharing this.
14
615
72Impala
72Impala
Clarksville, TN
72Impala
    May 18, 2024
    May 18, 2024
