Audio Components - Technical Advice Needed
Sawyer
CarAudio.com Newbie
Hello All,
I am new to this forum and am new to car audio components/setups. I tried doing as much research as I could before my head exploded as there is so much to consider when deciding on your components. I have a 14 Tacoma Double Cab (no JBL) and plan on adding a head unit, speakers, 2 10" subs and 2 amps. Below is a list of the components I have decided on, can the experts here tell me if everything looks like it will match (specifically the amps/speakers/subs)? I want to make sure I have my watts, ohms and anything else covered before pulling the trigger. Let me know your thoughts or concerns!
Head Unit: Kenwood - 7" - Android Auto/Apple® CarPlay™ - Built-in Bluetooth - In-Dash Digital Media Receiver - Black
JL Front Door Speakers/Tweeters: https://www.crutchfield.com/p_136C2650/JL-Audio-C2650.html
JL Rear Door Speakers: https://www.crutchfield.com/p_136C2650X/JL-Audio-C2-650X.html
10" Kicker subs (2): https://www.bestbuy.com/site/kicker...-ohms-subwoofer-black/5190204.p?skuId=5190204
Front/Rear Speaker Amp: KICKER - PXA-Series 300W Class D Amplifier with Selectable Electronic Crossover - Black
Sub Amp: KICKER - CX 1200W Class D Digital Mono Amplifier with Variable Low-Pass Crossover - Black
Sub Box: https://www.ctsounds.com/products/b...ble-cab-2005-2019?_pos=9&_sid=a2fe4dc4b&_ss=r
Big sound in tacos is Easy to achieve. Your route with component selection/location i would give a 5/10. Ideas
-Skip upgrading rear door(could even leave em disconnected).
-get a deck that has active/network capability and run front (tweeter), mid (front door6.5) and rear(sub). You will have better loud, tunability, and blending factoring the distance between your front stage and subs.this will be less money too. That kenwood doesn’t do active. The excelon model (dmx706s)has active. You don’t need that short chassis design for your truck. I like this pioneer better for a 7” screen
- I’d Pass on everyone of those speaker, woofer, and amp choices for the output/quality/cost
Value.
- get an enclosure that’sdesigned for the subs you choose. I’f you’re not going to install go/find a local competent installer to build you an enclosure to the sub specs.
Value.
Lulz, thanks for the score. Next!
not sure how to receive that. I gave you the longest
And realest answer you will likely get for a noob post asking about your setup and the assumption that you didn’t use any of the search function to search old threads. If you mean on to the next Response it will likely only be from someone tells you your Selections **** and are all overpriced without giving you any constructive direction.
Lulz, reported. It was obvious from your original post the kind of person you are, now it is confirmed. Willing to take some reasonable advice at a reasonable tone (e.g. not a condescending douche) without scores from anyone who is willing to have that reasonable discussion.
A Score gives you a starting off point, I guess saying your initial selections were super mediocre at best Is the delivery of choice for over sensitive libtard gen-z’ers. See I can make errant And inaccurate assumptions based on toneless message board thread responses too.
it started with you asking “technical advice”
on a zero parts Gear list lob thread, then you **** on the first person to give you solid insight citing dochey delivery. Man if you stick around you’re going to hate this forum ...there aren’t many contributors that specialize in the language of coddle culture
my intent was to give you sound insight and maximize your pending investment, now I’m only in it to see the responses
The link took me to a dual 2 ohm sub. You want dual 4 ohm subs wired all in parallel to get a 1 ohm load which the mono amp is rated for. I am assuming you are wanting to compete in sound quality because you are looking at 2 tens instead of 4 18” s. For sound Q the previous post is accurate, you don’t need rear speakers. Also the money you don’t spend on rear speakers can be put to use on better front speakers, not that the JL’s you selected are bad but you might be able to get the next model up. If you are set on the products you have selected then they look fine except for the subwoofers. Kicker will make the same ones with dual 4 ohm coils so no biggie. I think that either way you go you will enjoy the system. For IASCA sound q you will also want to turn down the bass more than you think. Good luck.
Hello All,
Headunit's good.
Front door speakers are good.
I happen to agree with BCotrell that you'll get more bang for the buck leaving out the rear speakers from the upgrade party and investing in better subwoofers. Rear door speakers add surprisingly little to a build, especially if there's no deadening behind them. I personally would leave the rear stock ones connected to the head unit and worry about them after I've addressed the rest of the system.
https://www.kicker.com/12CX12001#specsection is a better link for that amplifier, Best Buy unsurprisingly uses maximum and RMS interchangeably which is misleading. Your selection of subs is underpowered if you'd like to get the most out of the amp. You'll still want two dual 2 ohm voice coil subs, but in the 600W rms range, 400W is a bit low especially for Kicker which doesn't underrate their subs by 33%, maybe 10% but their SQ isn't known to be great. If I were you I'd omit the rear speaker upgrade and use the money to step up to 2 DVC subs in the 550-600W range. You can always meter your amp in, but since you haven't bought them yet I would say buying stuff with the expectation of upgrading it soon is bad particularly when the proper enclosure hinges on the future choices.
As I said, enclosure will depend on the subwoofers chosen.
Edit: 4-channel amp's good.
Also the mono-amp is only stable down to 2 ohms, so the 4 ohm DVC suggestion isn't correct. I don't know why the sites are so shitty about wording on the ratings for it. Switched from Crutchfield link to Kicker link which shows 1200Wx1 @ 2ohms, so it's not 1 ohm stable and you'll want 2 DVCs 2ohm 550-600W subs for that reason.
Headunit's good.
For $269 on that Comp set I’ll take flutes and ct2’s (or a number of alternatives on parts express), invest a few more bucks in my headunit for better crossover Control, grab 36 sq ft of noico to soundtreat them big metal Toyota doors, and still pocket $50 bucks.
also, $230 for a 4x50 amp and $350 for a 600 watt amp. $580 for maybe 800 watts is not great value Way more options for separate amps value wise. a gmd9705 5 channel will put out the same audible power as the amps he listed.
that was General direction of my feedback but op got caught in his feelings.
Yeah that sounds better for sure. It is what it is, I guess if strangers treat you like you're one of the club too quickly you're bound to get offended quick fast in a hurry if you don't have a thick skin.
The amp he mentioned is 1200W @ 2 ohms RMS despite the horrible layout by Best Buy. gmd9705 would be good. With the price ranges he's at and with the subs he listed it sounds like a 5-channel would be better unless he really does want to ditch the subs and pursue some to match. I would lean towards https://www.crutchfield.com/p_575R21200X/Rockford-Fosgate-R2-1200X1.html instead of the kicker or maybe a taramps. I think both brands you get more for your money, but you've just gotta be careful to get a taramp with variable filters. That would mean 2 DVC @ 4ohm subs instead, but slightly more power for the money. My R2-1200x1 is pretty far under rated according to the third party tests RF uses anyways.
Headunit's good.
My bad, I should have done a little more investigation before my reply 👌
I have a 2004 X-cab Tacoma
Have a Pioneer FH-S701BS HU, Pioneer TS-Z65CH Hi Def component speakers front, Kenwood Excelon XR401-4 Hi Def x2 amps one bridged subs, one 4ch mid & tweet & rear, Pioneer 6x8 coaxial read panels, Subs Polk Audio 8" x2 in old Kicker Substation tube boxes.
Rear 6x8 are mild sound with just little rear fill. Sound system sounds good and is Hi Def rated. The Pioneer has active on HU. If you don't need a screen it is an affordable cost unit. It is a discontinued HU end of 2019 but still can be found. Great HU for the cost. The Pioneer component speakers sound great.
Getting two Pioneer GM-DX874 4ch amps to install. There in shipment & soon to be installed.
Just don't need a lot of equipment to get plenty of great sound & volume out of a smaller cab area.
Wish you the best, enjoy
Yeah I really like that rf 1200. Birth sheets like 1400 ish
I had the older version of that deck in my sequoia when I wanted to fill a 2din slot without the gap and didn’t want a screen. It was a good unit but mine didn’t have active. have you personally tried connecting those Front components separately from the passive crossover direct to each amp channel and leverage your deck for crossover? Probably could optimize sound even more and will really open up when you get your 8704.
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
total steal right there! Those midbass drivers in that set are excellent! They have solid output from about 90hz and above but if installed...
10
These have been used for a few months and then were pulled for pro drivers to take their place for more output. These are 4 ohm drivers and in...
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
916
Sawyer
CarAudio.com Newbie
Sawyer
Portland, OR
tmorreno5
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
