Dsp crossover starting point
  • 3
Jimg
CarAudio.com Regular
216
13
what is a good starting point for the dsp setting in a full active setup
subs. 10 inch. 80hz? Or would you go higher
door speaker. 6. 1/2. What range would you start with
door speakers. 5. 1/4. What range
dash tweeter. What range
80hz is a good starting point for your sub, assuming your midbass can get down that low. My starting point will be 80hz sub, 80-3500 hz for the bandpass and 3500hz high pass for the tweeter. That’s based on the frequency response for the speakers I am using. It’s obviously different for other types of equipment.
I used Sancho as a distraction to get approval 😳
61
4K
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
955
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
567
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
522
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Jimg
Jimg
Louisiana_CRX
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
