Audio cutting out
Is it doing this on streaming music? It's not doing this on the radio, flash drive, or CD correct?
Im having an issue where my audio just started cutting out for a out a second than the music comes back on but playing at a fast pace like if its fast forwarding to the seconds it cut out. Any ideas why?
I get the same issue when the cellphone signal is spotty.
Had it happen with streaming services, including the "fast scan" part.
What's your hardware and music source?
Could be an audio buffer. Sometimes they fill up then dump to make room and have to play catch up so to speak. I have only had this issue on CD players though that had anti-skip features.
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
150
Ill check it out. I was actually on the site last week. Thanks!
284
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
300
Name'sDEEZ
CarAudio.com Regular
Name'sDEEZ
Earth
ThxOne
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
