Audiobahn Sub need amp help
javi96
Texas
I need a amp for my Bandpass AudioBahn 12'Subs but not sure which one to get can someone help me out? and suggust one the? info about it is below.
Power Handling: 800 Watts RMS
Sensitivity: 103dB
Frequency Response: 25Hz - 140Hz
Impedance: 4 Ohm Stereo
Im not that familiar with amps but if it helps just go with the whole audiobahn setup. ya know, get and audiobahn amp. Thats what im running and im totally satisfied. A friend is running some audiobahns with and mtx amp and its pretty fly but its an older mtx amp and I think the olders ones are better.
You could stick with an audiobahn amp if you have the cash. I'm not sure I'd recommend sony for anything car audio but I've never heard or used their class D amps so I have no comment on them.
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
202
541
572
javi96
javi96
Texas
LegendZ28
