AudioControl question
  • 3
sstumpf
I am wanting to put a single 10" and upgraded front components in my 11 silverado. But keep the factory HU. Using a 5 channel amp.
Question is, can I get away with using the lc2i tapping into the factory rear speaker wires for my full range signal. Then using the main output on the lc2i for the front component set and use the bass output for the sub channel? Sound like it should work, just wanted to make sure.
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
697
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
sstumpf
sstumpf
Fisher, IL
sstumpf
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
