audiopipe APSM 1300 for JL Sub
Do you have a suggestion for something that would be better around the same price. like around 120. And what do you mean by clean power.
i have used the apsm1300, and at a 4ohm load you just do just fine. or you could step up to the apsm1500, i think there are some for sale in the classies. clean power is unclipped/undistorted power. if gains are set properly and not maxing out, and never ever use the bass boost, you should be fine.
FYI I wanted to point out we have this amp available for about $105, not sure where you were getting it but I saw you had mentioned the $120.
If I were you OP I'd get a nice 2 or 4 channel and bridge it to give it what you want. That way when you upgrade you've got a good amp for your doors.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Do you still have this? Where are you located?
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
Also if you did decide to get another amp the output rca on the amp can be adjusted with the internal dsp
6
osupur8800
osupur8800
Ohio
DoesDad
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
