Audison amp not powering on - advice needed
  • 2
D8V3
Hi all, I'm new here and I've come in search of some expert knowledge! I've been into car audio ever since I passed my drivers test back in 2006 and I used to dabble a lot then with amplifiers and subwoofers. Around 2015 I undertook the task of running new speaker wire through into the doors of my S2000 which I would never wish such a task upon anyone! Back then amps and wiring simple but this new stuff these days?! I've recently bought a BMW M4 which I thought was standard but when looking under the carpet in the boot low and behold two expensive Audison amplifiers.
I originally went investigating because I wanted to add a sub woofer to my system. I have attached some pictures so that you can see what I already have. It would appear to be very nicely fitted already and I would imagine it was done by a shop professionally.
So from the images you can see that on the bottom I have an Audison AP F8.9bit amplifier powering all of the speakers around the car, this is working fine and I have no issue with this. However the amp on the top (a mono 1ch amp Audison AP1D) is not powering on. There is a lose speaker wire hanging around in the boot but the light does not come on when the car is on. I have put a multimeter in the positive and negative terminals and it is receiving power. Could this be because no sub woofer is plugged in? I don’t know. Will the amp only power on when it is getting power drawn from a sub? The only random speaker I have hanging around is a home audio speaker - I tried plugging that in and still no light on the amp?
The amount of wires in the back is truly baffling and I dont even know where to start troubleshooting?!? Any advice would be great!
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to purchase a decent amp and sub, run power, turn on wire and ground. Pull the signal from the existing amp or other speakers. Or you can go to the dealer or a stereo shop and use your children's college fund to get it fixed.
Good luck.
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
Yes mate I have these in a 3 way active front stage and they sound great, have them crossed at 5k, see my recent post for full breakdown of kit I...
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
D8V3
D8V3
United Kingdom
huberoy123
    May 16, 2024
    May 16, 2024
