Avic-N3 please insert disc problems.
  • 2
dye4metal
Tampa, Fl
i just burned the 09 map disc and im in FL and i burned the east coast version and my HU started up on it and up dated and all that jazz but when i click on the nav button it still says please insert disc??//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
I burned the CNDV-90MT a few months ago after d/ling it form a torrent site. It worked fine on my N3 and worked on my N5. I suggest trying to burn it again at a slower speed or a different burner, or with higher quality media.
It's most likely a bad burn, otherwise it's the hardware.
i reburned one and now when i start it up it goes to the starting pioneer navigation system but sits there for forever. and i have yet to get it past that screen. the mp3 and cd player work great though? should i try the next burn at 2x?
What kind of media are you using to burn it with? Don't use cheap DL DVDs. If the mp3 player and cd player are working, it's most likely a bad burn. I would burn it again at 2x with Verbatim Discs.
It also might be the DVD burner itself. Try burning it on another computer or a newer burner.
i have the new memorex dvd dls. ive made a disc in the past that worked but was with sonys. it said disc error on the 2x disc.
Like I said if you're getting burn errors, it may be the burner itself. Try a different burner.
Sorry, my header could have been more specific. Anyway, I might be the only one, but I want to get rid of the large AV source window on the main...
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
5
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
658
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
562
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
dye4metal
dye4metal
Tampa, Fl
Zermelo
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
