B Quiet Extreme or Dynamat Extreme?
Maglite
It comes in Black
I'm looking for a good product to put inside my car before I put the interior back in.
The B Quiet Extreme looks like it can be had for a good price.
Is the BQuiet a good product or should I save up for some Dynamat Xtreme?
How closes are they to each other?
Looking for advise
Thanks
i have used dynamat its kinda pricey but works well .
ocs sells it at a good price usually
i have heard bad about bquiet but you know how the webz are if they dont use it it must **** so take it with a big grain of salt.
anything is better than nothing so cheap is not bad if it works
just stay away from peel n seal lolz
i have used dynamat its kinda pricey but works well .ocs sells it at a good price usually
Thanks......Who is OCS?
Looking for advise
Thanks
DAMPLIFIER PRO
Out of Dynamat Extreme and B-quiet, dE is a much better product
The adhesive is designed to be used in a car (not on a roof like b-quiet, which is roofing tape resold as a vibration damper)
The foil on DE is twice as thick as the foil on BQ, which is a huge benifit. HUGE!
4 mil foil compared to 2 mil foil is going to do a much better job damping.
Dynamat extreme is better in every way, except price.
ANT
Out of Dynamat Extreme and B-quiet, dE is a much better productThe adhesive is designed to be used in a car (not on a roof like b-quiet, which is roofing tape resold as a vibration damper)
ANT
KUDOS ANT U DA MAN DUDE !!!
he is the competition to dynamat and yet still honest!!!
dynamat or second skin are both awesome
ocs= http://www.onlinecarstereo.com
ANT
Thank you for your honest straightforward review.
Dynamat Extreme for sure. I've even tried the Damp Pro like mentioned and would rather use Dynamat Extreme. I have used and installed probably 30+ bulk kits of Dynamat Extreme without any problems or loss of quality and I won one small kit of Damplifier Pro from a Db Drag show I went to a few months back. The Damp. Pro had voids in the material all over causing it to have LOTS of air bubbles underneath. Needless to say I'll never buy it.
All Ill ever used he Dynamat, at least as long as my boy works @ Best Buy and I get it for less then 1/2 price!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Four door kits for $160 FTmfW....
The first thing you should do is double-check all of your wiring connections. Usually when people come to me with this issue it's a loose ground...
942
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
991
I would assume it is the radio's built in eq curves that are meant to protect the OEM speakers. You will need a DSP with signal leveler. That...
5
989
I forgot what brand I have has plain foil no logo. I placed 4 x 4 squares inside the doors a few inches apart and full coverage on the inner skin...
22
3K
Maglite
It comes in Black
Maglite
North of L.A.
Maglite
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
