Subs gone quiet
  • 3
bumpin_boosted
CarAudio.com Newbie
nevada
I run a 2x 15’s 3:1 blow through box in my truck and usually around 155db’s 3 days ago it was fine and had been for almost a year no issues but today it is hard to tell they are even there so quiet that my mid ranges muffle them
Help please
The first thing you should do is double-check all of your wiring connections. Usually when people come to me with this issue it's a loose ground or a bad RCA cable.
If everything is snug, grab a multimeter and set it to Voltage AC and probe the RCAs going to the amp and the speaker leads. Depending on your head unit/DSP, you should get anywhere from 2-6v at full volume on the RCA.
Since you said you're capable of 155 db, it's clear that you have some decent power. Voltage = ✓(watts x impedance). With this is mind, probe the speaker leads and see what voltage you're getting. 3000 watts is about 54 volts @ 1 ohm, for reference.
I'm willing to bet this will solve your dilemma.
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
762
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
327
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
430
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
699
Look at the Alpine Type S subs.
19
bumpin_boosted
CarAudio.com Newbie
bumpin_boosted
nevada
TheBigPilferer
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
