Back up camera power source
  • 1
dean7276
Hi all, Happy Holidays. Newb here with a newb question. For a rear view camera I understand you have to wire the reverse trigger wire to the reverse lights but can you wire the red 12v wire to the reverse lights too since the only time I want the camera to be on is while in reverse? or do you want the camera wired to be on at all times and just sending a signal while in reverse?
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
It only works when the car is in reverse. Also, some units have trigger options in the settings menu.
578
Try to reset again and if that doesn't work, try updating the firmware. To update the firmware for Alpine X800D, you can follow the instructions...
How positive are you that the reverse camera power supply was spliced in with a reverse light wire? If you used one of those blue wire splicers...
That looks like it can work for backup cam for sure, thanks
921
dean7276
dean7276
Fort Worth, TX
dean7276
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
