Baffle vs sub diameter size?
ᛒᛚᚨᛞᛖ
CarAudio.com Recruit
54
30
SE
Purely structual question:
How much larger should my baffle be than my sub cutout?
Example:
AB XFL 15 with a 14.'' cut out mounting in a 16'' x 36'' baffle. This would leave me 1'' of wood above and below the cutout.
Would that be enough or would I need more than 1''?
Edit: Will be double baffle so 1.5'' thick.
With a subwoofer the answer is whatever fits your design limitations without compromising structural rigidity. Look at it in terms of stiffness and rigidity rather than an actual numerical figure.
Can you feel vibrations when you touch the baffle as the driver plays?
Answering yes means the baffle needs extra stiffening to get rid of that vibration.
I haven't built the box yet. Was hoping there was a general rule of thumb for my q kind of like ''
you should use at least 3/4'' plywood for your box because .5'' is not strong enough.''
I did see those w that skirt that bridges the gap you refer between speaker lip and door grill and these don’t have that. Just flat behind the...
656
I just built a system not long ago in my 2008 C300. I actually cut out the partition behind the arm rest in the rear seat to act like a port. I...
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
Unless something has changed DD designs it's subs to be ported. The Gcon would be a better option for IB.
ᛒᛚᚨᛞᛖ
ᛒᛚᚨᛞᛖ
SE
    May 22, 2024
    May 22, 2024
