Bass loss when driving, sounds good when stopped
  • 4
grandam888
Noticed lately my bass is almost non existent while driving, but when at a light or something, bass hits nice.
System is not the one listed in my signature, running 12" hifonics sub(inverted with phase reversed) on a 300 watt JBL monoblock amp wired at 2 ohms, 1 cube box tuned to 38hz all electrical upgraded including big three. Old school 4 channel planet audio on my highs with jvc headunit.
My voltage at a stop with system running is low in my opinion, about 12.4, not sure why, but driving voltage is near 14 volts. This strikes me as odd as the amp is actually louder on the low voltage as opposed to the 14 volts.
I have zero ground loop noise from what I can tell.
All help is appreciated, thanks
I cannot hear any ground noise in my stereo what so ever, but I can try to move my highs over to the stereo and disable the amp I am using for my highs, I guess while I am at it check my connections on my power wires.
Is is possible my alternator is getting ready to go out? 12.4 volts idle is pretty bad in my opinion
Yes, that voltage is not good. It should be at 13.5 (lowest) and up. Make sure it's not your battery not holding a charge. Check the voltage of the alternator by using a DMM on the charge wire.
LOL, I thought he meant I was hearing ground loop noise.
I will check the voltage on the alternator today, I have a spare so changing it out would be free.
As far as the road noise, I doubt it. I have had some small systems in the past and never had this issue. Oddly I have noticed the air conditioner is doing something similar, it blows colder and better at idle. I'm leaning towards alternator as these symptoms are not something I remember having when I installed the system over a year ago.
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
10K
Hello! are you found the cause? I have similar problem. Sound like Sh*t bass :/
8
SI makes nice subs. I'm an XBL guy myself, but I tend to listen to neutral/flat sounding drivers in general.
17
688
grandam888
grandam888
houston, tx
grandam888
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
