Battery terminals
  • 3
brafferty
idaho
I currently use just normal rind thermals attacked to my standard rind that locks onto the battery. I see there are these things that you can put your wire directory into that attaches to the battery and am thinking that my help look like a cleaner install. If I have the biggest g 3 upgrade done, would I be fine strictly using the 0 gauge terminals and ignore the stock grounds that originally were on the battery? I. It currently have the old and new grounds attached to the battey
I think the question regards whether or not he can remove the factory wiring with his big 3 in place for a cleaner look. If that's the question, the answer is yes, so long as you have replaced everything with regards to the wiring you plan on removing.
yes this answers half of my question //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif the other half is more so an opinion but, would you recommend using a device such as this?
Amplifier Wiring Kits
I mainly ask because my stock battery lock (not sure what the heck to call it) doesn't like to tighten down with all my ring terminals hooked up to it, creates wiggles br is fine when they are not attached
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
6
755
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
359
brafferty
brafferty
idaho
brafferty
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
